JDPlowboy Posted January 17, 2016 Report Share Posted January 17, 2016 It is stuck on a sensor over temp reading. It will not clear, even if the sensor is disconnected. Can it be cleared? Tia. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted January 18, 2016 Report Share Posted January 18, 2016 Hello, This sounds like the M90 unit was previously programmed by someone else. Is this true? Do you have the application that we could review? If so, please send this into support@unitronics.com If this was programmed by someone else, please try to get in contact with them for further troubleshooting. Quote Link to comment Share on other sites More sharing options...
