mcmahoney Posted August 11, 2010 Report Share Posted August 11, 2010 I am using a string library to list strings in a text box. I am using the indirect method. So I have slected a MI for the row number in the string library to be displayed. It seems to work fine, except when I change the string row number, the string that was in the text box originally doesn't go away, it just gets written over with the new string. I have added, for test purposes a screen refresh button and the origrinal text screen clears and the new string is only visible. Do I have to do a screen refresh anytime that I change the row number in the string library? Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 11, 2010 Report Share Posted August 11, 2010 No, it probably happens because the text has a transparent background. Quote Link to comment Share on other sites More sharing options...
mcmahoney Posted August 12, 2010 Author Report Share Posted August 12, 2010 That was it. Thanks Quote Link to comment Share on other sites More sharing options...
