Gugulanov Posted February 18, 2016 Report Share Posted February 18, 2016 Hello,I'm writing this in separate topic, just to be clear for all.It is obviouse that we can change online and download ports in pop up menu of PC-PLC connections. But I cant understand where in my project is the place for defining these different ports, like e.g. the screen for setting Web server - there we have field for port, and web server is working fine with port forwarding option in a router.So, what is the solution for using different ports for download and online, in order to connect to PLC with port forwarding router. Any advise? Regards Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 18, 2016 Report Share Posted February 18, 2016 "So, what is the solution for using different ports for download and online, in order to connect to PLC with port forwarding router." Yes, so you can connect from the internet to one IP address, and give different ports and be able to connect to different PLCs. Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted February 18, 2016 Author Report Share Posted February 18, 2016 1. I mean, that if I change the default ports (3335 and 22) in "PC-PLC communications" with my own (for instance 30003 and 30004), I can't connect to the PLC. 2. I can't find option to change ports of communication in the project. 3. I can't find port configuration in UniApps... only IP settings in Network/Ethernet. So, what am I missing? Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 24, 2016 Report Share Posted February 24, 2016 I think you should be able to configure a NAT where connection to port X goes to IP A and port B, and connection to port Y goes to IP C and port D. Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted February 24, 2016 Author Report Share Posted February 24, 2016 I don't have problems with setting of router itself to forward specific port. Let suppose that we don't have router, and we have ordinary ethernet connection to the PLC (laptop is directly connected to the PLC). If I use the default online and download port (3335 and 22) in "PC-PLC communications" - connection is OK. If I CHANGE the ports to different - there is no connection. What must be done to have connection on non-default ports? Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 25, 2016 Report Share Posted February 25, 2016 Currently, those ports are not configurable. Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted March 12, 2016 Author Report Share Posted March 12, 2016 Do you have a plan to include option for configurable ports in future versions of Unilogic? Quote Link to comment Share on other sites More sharing options...
Saragani Posted March 14, 2016 Report Share Posted March 14, 2016 Currently not, and changing those ports from the PLC will also affect the USB connectivity (because the USB is an RNDIS Gadget, which means that it is Ethernet). When you connect directly to the PLC, you don't need to change the ports. Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted March 15, 2016 Author Report Share Posted March 15, 2016 OK.Thank you. Regards Quote Link to comment Share on other sites More sharing options...
