John Knoop Posted February 24, 2016 Report Share Posted February 24, 2016 I am writing a value every 10 seconds in a data table for 1 hour. So I have 360 values. How can I calculate the average over 360 values ? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 24, 2016 Report Share Posted February 24, 2016 Hi, You can read Data Table column into vector of 360 MIs. Then make SUM into ML or DW, then divide by 360. If you are interesting in right rounding - check SDW 4 or SL4 and correct result. B.R. Quote Link to comment Share on other sites More sharing options...
John Knoop Posted February 25, 2016 Author Report Share Posted February 25, 2016 Hi Alex, I am a beginner. So can you show me a example? Thanks Quote Link to comment Share on other sites More sharing options...
