soliton Posted February 25, 2016 Report Share Posted February 25, 2016 Hi, I recently downloaded and installed the latest version(6.6.13) of U90Ladder, and found out the "Select Operand And Address" window in nowhere to be found when I edited ladder code and need to assign operands to functions. Uninstall, check UAC was disabled, and then re-install did not solve this issue. Visilogic installed on the same PC does not have this issue at all. Any remedies? Quote Link to comment Share on other sites More sharing options...
Alexander Posted March 8, 2016 Report Share Posted March 8, 2016 Have you worked with a second monitor previously, then removed it? It could be that the window is located in space that you can no longer see. If this does not solve the issue I would recommend uninstalling then reinstalling the software. Quote Link to comment Share on other sites More sharing options...
