nktasingh Posted March 21, 2016 Report Share Posted March 21, 2016 I'm trying to figure out where the PLC scan starts for a PLC running UniLogic. Is there a predefined "main method" as in Visilogic? Otherwise, how are methods called? Quote Link to comment Share on other sites More sharing options...
Saragani Posted March 22, 2016 Report Share Posted March 22, 2016 There is a main method, but it can be changed. You should see a Ladder Module marked in Bold, and a function masked in Bold as well. Theses are the Main function, and the module that contains it. If you right click another function in the Tree, then you will see that there is an option in the context menu to set it as Main function. Quote Link to comment Share on other sites More sharing options...
nktasingh Posted March 30, 2016 Author Report Share Posted March 30, 2016 Can't believe I missed that, thank you! Quote Link to comment Share on other sites More sharing options...
