kris9660 Posted April 4, 2016 Report Share Posted April 4, 2016 Hey, i have a communication problem after i download a program with a SI141 (STX) -1 (no start of text). Can i change SI141 offline or can i do a factory reset. Link to comment Share on other sites More sharing options...
s.pratt Posted April 4, 2016 Report Share Posted April 4, 2016 Hello, Are you trying to communicate with the unit via U90? You may try to reset the communication parameters back to their default settings in info mode. You can enter inifo mode by pressing and holding the ( i ) key for 5 seconds, then searching the "system" options for the RS232 parameters. You should then be able to connect in U90. To change SI141, you will need to do so through the program or while you are in Online Mode with the unit. Link to comment Share on other sites More sharing options...
