JC87 Posted April 22, 2016 Report Share Posted April 22, 2016 Hello, I'm new on Unitronics plcs, usually I work most of the time with Siemens and Schneider plcs. So I created a new unlogic project using the Pre-defined operands" option, I get eventually several bits arrays areas like MB (memory bits array) and XB (X bits array) but I don't understand what's the difference between them, I can't find something about it in online help. I'd like an explanation about those areas, thanks. JC Link to comment Share on other sites More sharing options...
Alexander Posted April 22, 2016 Report Share Posted April 22, 2016 The option to create a project with the Pre-defined operands will automatically create sections of tags for you, similar to how they are set up in our VisiLogic software. Otherwise a regular project has memory to use and build from as you go, but each tag can be added manually only using the required amount of memory. The difference between the MB's and XB's are that MB's are retained memory while XB's are not and will be reset to 0 when the controller cycles power. Link to comment Share on other sites More sharing options...
JC87 Posted April 26, 2016 Author Report Share Posted April 26, 2016 Morning, Ok now it's clear for me. Thanks for the answer. JC Link to comment Share on other sites More sharing options...
