MartinIT Posted June 9, 2016 Report Share Posted June 9, 2016 I need to drive axis motion with continuous change. I do not want to stopped after the end of the track, but continued without stopping.It is possible through the PTO? What hardware can I use for it?Can I use stepper or servo? Martin Link to comment Share on other sites More sharing options...
Ofir Posted February 5, 2017 Report Share Posted February 5, 2017 Hi, As I understand you wish to send continues pulses to the drive. In this case you can use PWM output of our PLC, once you set the Run MB it will not stop generating the pulses until you will reset this bit. The frequency and other parameters are model depended. Link to comment Share on other sites More sharing options...
