nong7215 Posted July 6, 2016 Report Share Posted July 6, 2016 i cannot forward port plc unistream (LAN 192.168.1.202 port 5900 for vnc) but i can forward port plc v350 is ok (LAN 192.168.1.200 port 20256 for download and online ) WAN 155.122.40.25 FIXED IP Link to comment Share on other sites More sharing options...
Ofir Posted February 5, 2017 Report Share Posted February 5, 2017 Hi, As I understand you are using UniStream and try to perform port forward for the VNC port. This should be possible as many of our customers already did it before. Basically you just need to configure it with the internal IP 192.168.1.202 and external port 5900 and internal port 5900. (The most important is that the internal port will be 5900). If you set the external port to other port than 5900 , you will have to configure you VNC client to this port. Please check if this port is not already configured anywhere in the router setting or it is kept for other use. Link to comment Share on other sites More sharing options...
