External Moderators tmoulder Posted August 13, 2010 External Moderators Report Share Posted August 13, 2010 Hi all, I'm currently working on a project where I have used over 200 timers. Gee, that's alot of timers. Additionally, alot of the code modules are similiar, so copy-paste-edit is the way to go for creating the code. That being the case, it would be really great if Visilogic offered a utility to check for duplicate coils. Specifically, I would like to be able to check if any timer is used more than once (as a coil) within the program (they should all be unique). Right now, I would have to do a search on each indivdual coil, and that's very time consuming. This should NOT be part of the compilation process, since there are some instances where you might want duplicate coils, and don't need compilation hanging up on it, or drowning you in irrelevant warnings. Just an additional option in the edit menu, along side the other "Find"s, would be great. Thanks! TM 1 Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 15, 2010 Report Share Posted August 15, 2010 Hi Tim, Thanks for the suggestion. I passed it to Unitronics R&D for review. Quote Link to comment Share on other sites More sharing options...
