Nikolche Posted March 9, 2017 Report Share Posted March 9, 2017 Hello all, I have an application with length measuring using encoder and HSC on V130-TR20. A want to drive(activate) a servo motor (paper cutting knife) always on counter reload for which I'm using _Interrupt HSC 2,3. But VisiLogic does not let me use PTO blocks inside interrupt (illegal element on interrupt subroutine) and do not let me call a subroutine (illegal element on interrupt subroutine). Any suggestions how to activate PTO in the same time while counter reload occurs? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 9, 2017 Report Share Posted March 9, 2017 Hi Nicolche, Yes, VisiLogic does not allow to use PTO in an Interrupt Routine. What are requirements for servo (do you mean stepper control by PTO?): -Is a knife movement one direction, or both directions? -Does knife, one time activated, cut and return to initial position, or it should be returned by opposite direction movement? -How long knife may stay at end position? -Can you use "High Speed Outputs (Stepper Control)" from Hardware Communication settings? You can send all details to support@unitronics.com. B.R. Quote Link to comment Share on other sites More sharing options...
