darknesspic Posted May 22, 2017 Report Share Posted May 22, 2017 Hi all I'm using EXF-RC15 with PTO function, I need to control stepper motor with speed range 0.008-0.4hz so I want to clearify 1. how to set "Unit" and "Pulses per Unit" in PTO config, and what meaning of these parameters 2. What is relation of "Unit" and "Pulses per Unit" in PTO config and "Velocity" and "target" in PTO move Thank you Quote Link to comment Share on other sites More sharing options...
