tester2 Posted March 3, 2011 Report Share Posted March 3, 2011 hello im testing igss scada with unitronics opc server connected to v570 The problem is that i cant get the igss to comunicate with the opcserver. If i use other scada like winlog lite i can access the the data from the v570 by usig tag MA1.MI50 but with the igss i just get that i connected to the opcserver but it does not add any communication with the v570. with winlog i can se in the unitronics opcserver log that it add MA1.MI50 but this not happend with igss is there anyone that can help me and test this and give me some tips or help/howto i see that someone has made a video from how to do this with intouch. maybe someone here can do the same with iggs. i would be great. Quote Link to comment Share on other sites More sharing options...
Ofir Posted March 7, 2011 Report Share Posted March 7, 2011 Hi, I’m not familiar with the SCADA IGSS settings but if it supports MODBUS driver then you can try also set the PLC as MODBUS slave. Then instead of UniOPC use MODBUS. Please see the slave addressing in Help Topic MODBUS. Quote Link to comment Share on other sites More sharing options...
