behator Posted August 9, 2017 Report Share Posted August 9, 2017 Hi, I have a problem with aplication. My Jazz should works a few minutes as Master after that switch to Slave mode ( in the loop). It works, I switch to Slave mode till set SB25 (Ethernet Connect / Listen Request), after that Jazz turns to Master (write 0 to SI214) ??? Someone can help me ? Quote Link to comment Share on other sites More sharing options...
