Raymno Posted March 8, 2011 Report Share Posted March 8, 2011 I have a need to compare project files written for the V570. Is there a utility like VisiDiff that can be used? Will VisiDiff be updated for the enhanced PLC's? Quote Link to comment Share on other sites More sharing options...
ofer.yishai Posted June 17, 2012 Report Share Posted June 17, 2012 Hi I was looking for a solution myself in the forum...but find nothing about a way of comparing two projects. Finally I think I found a way of comparing at least the ladder: Right click a single subroutine at a time, click STL-Quick-View Press "E" to export to excel. Do the same for the other project to compare, Copy the two lists side by side on a single sheet. Now you can compare relatively easy two excel lists. for better comparing any difference found on a ladder view you can open two instances of visilogic side by side:look http://forum.unitron...e__hl__visidiff If anybody have a way of comparing other project parts like HMI screens, I would be glad to hear. I wonder when Visidiff will support enhanced PLC's finally ????? Ofer Quote Link to comment Share on other sites More sharing options...
