Jakke_SL Posted September 22, 2017 Report Share Posted September 22, 2017 During installation (updating) of the new unilogic software the computer blocked. It is a laptop Toshiba with Windows 10 installed. See included the 2 messages I receive every time I try to install the new software. Help, this is urgent, because I'm occupied with a large project. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 22, 2017 Report Share Posted September 22, 2017 If you have CCleaner, then you can uninstall UniLogic with it (it will remove the program from the installed programs list). Then, follow the instructions here: It is important to run the command line as administrator. Tell me if it worked. Quote Link to comment Share on other sites More sharing options...
Jakke_SL Posted September 24, 2017 Author Report Share Posted September 24, 2017 I have Ccleaner, but every time I want to uninstall Unilogic, I receive the same message: "1628: failed to complete installation". I have cleaned the register with "Registry Repair Pro", but the result stay the same. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 24, 2017 Report Share Posted September 24, 2017 In CCleaner, there are few options. One of them is Uninstall (which will tun the uninstaller, and you will get the same error). The second one is Delete, which is what you want. It removes traces of the deleted program from the registry, so windows thinks it is not installed. Quote Link to comment Share on other sites More sharing options...
Jakke_SL Posted September 25, 2017 Author Report Share Posted September 25, 2017 It works! Thanks for your assistance. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 28, 2017 Report Share Posted September 28, 2017 You are welcome Quote Link to comment Share on other sites More sharing options...
