jeepers52004 Posted November 29, 2017 Report Share Posted November 29, 2017 I've been getting a CPU error on my panel the last couple weeks that forces me to reboot the PLC. Seems to happen every day and a half or so. I noticed this morning that the date/time reported on the error popup was 12/30/00 and 9:50am, both of which are incorrect. I tried setting the RTC via UniApps - this allowed me to pick the date but upon selecting ok, nothing changed on the displayed date. Same thing with the time. I tried setting the RTC via UniLogic/UniStream Management/Set RTC and although it said the task completed, the date and time remained unchanged. I was able to change the values in the tags in UniLogic when in online mode, however, the it appears the clock isn't running - no change in seconds or minutes. See attached for screen capture of the error and of the software rev info. Any help is greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 30, 2017 Report Share Posted November 30, 2017 Can you send the project to the support? The R&D will try to reproduce the CPU error, and if it happens when we can investigate the issue. 10x Quote Link to comment Share on other sites More sharing options...
