Connect to MySql server with "SQL Connector"
Hi everybody,
I'm struggling to make a controller to submit data from a controller USP-070-B10/B08 to a MySql Database that stays on Amanzon cloud.
I made a project using Unilogic v 1.19.83 same as the one in the controller. Did the connections and queries I wanted but nothing happens. it looks like it's not communicating at all with the database. I'm not even seeing a connection in my server manager.
There is any tutorial, hints or something somewhere to guide me (I attached some screens as well)?
Thanks
More updates . Not sure if the DNS is correct but now I know what error I'm getting :)
              "2003 can't connect to MySQL server on ip address  (101)"
Nevertheless, I can't manage to make it working. I also installed MySQL server locally and didn't work either. It must be something on PLC communications settings or it doesn't like MySQL.
Does anyone has a project with a basic query for MySQL that works so i will modify only the communications and database server?
Thanks
Quote
Does anyone has a project with a basic query for mysql that works so i will modify only the communications and database server?
In the link I already mentioned in the previous replies ( "SQL Query" function block usage) there is already a working "SQL Connector" configuration, just change the IP, Port, Username & Password.
Quote
Use the information in this link "Unitronics Technical support" on the SQL section. There is a guide written by  Unitronics Support that will help you troubleshot your issue,
UPDATE:
The issue resolve and ciprian.savoiu is able to query his DB (informed us by mail).
