Solution Save failed
Hi,
My UniLogic Solution failed to save intermittently.  If I keep on saving, eventually it will saved.  Is there a way to clean up this solution?  Please see the screen capture and SolutionHandler log attached.  Thanks in advance.
Anthony
08:34:08.9961 5740 Fatal IOServices.SaveSolution => SolutionHandler.SaveSolution SaveSolution  EXCEPTION OCCURRED:System.Exception: The new ulpr file did not pass validation
   at Unitronics.Database.SolutionHandler.SolutionHandler.SaveSolution(FileSaveStatus& result, String& safeProjectBackup)
08:36:08.2731 5740 Fatal IOServices.SaveSolution => SolutionHandler.SaveSolution SaveSolution  EXCEPTION OCCURRED:System.Exception: The new ulpr file did not pass validation
