grahamtj Posted December 11, 2018 Report Share Posted December 11, 2018 Can I change the baud rate of the CAN bus from within the program, even if I have to reinitialize the CAN bus? The "CAN setup.Baud Rate" tag is a read-only one. Backstory: Depending on the device I want to connect and test, I need to set up the CAN bus for 500 Kbits/s or 1Mbits/s. PLC: USP-156-B10 (15.6 inch PLC) Unilogic Version: 1.25.56 Thanks, Graham. Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 11, 2018 Report Share Posted December 11, 2018 Right now you can change the baud rate from the UniApps. It is planned to allow changing baud rate and other properties from the program itself. I can't give information about when it will be released, and which properties will be changeable since the development of this feature has not been scheduled yet. Quote Link to comment Share on other sites More sharing options...
