Kamil Posted March 29, 2019 Report Share Posted March 29, 2019 Hello, is there a way to increase cycle time of canbus? Now it sends info every 2 ms while I'd like to have it around 2000 ms 🙄 Thank you! Kamil Quote Link to comment Share on other sites More sharing options...
Ofir Posted June 5, 2019 Report Share Posted June 5, 2019 Hello, Which protocol are you using over the CANBUS? If the PLC is sending the data then it is possible to control timing of the messages - if the sender is a third party device then you should configure the device to increase its interval. Quote Link to comment Share on other sites More sharing options...
