PaulTailleur Posted April 10, 2019 Report Share Posted April 10, 2019 Hello, I have the V700 with a Snap-In V200-18-E2B and a Inverter. I want to run a motor with a simple programs. I want the V700 communicate in RS485 with the inverter. I use a USB cable to send the program to the V700. I know i have to plug my RJ11 cables in the port of the V700 and set the communication on RS485 on the bottom of the V700. For the other part of the cable i have to take 2 of 4 wire and connect them on the Inverter. What i have to do after ? How i set the communication ? Will i have to create programs with contacts and coils to run the motor forward, or it have a compiled programs which contains some of these command ? Thanks, Quote Link to comment Share on other sites More sharing options...
DanT Posted April 10, 2019 Report Share Posted April 10, 2019 Hi Paul; Have you programmed a PLC Before? Have you downloaded and installed Visilogic 9.8.65 on your computer? www.unitronicsplc.com downloads Visilogic Visilogic 9.8.65 Open Visilogic, and click on Help, Open Up Examples, and look thru them., Convert them to work with the V700 ( Hint -- Convert to Color), Build them download them, test them , understand them. There are the basics to review, and then there are RS485 examples under Projects, Communications. Ccreating your own small test programs and build up from there. Also review the Inverter communications parameters and how it wants to share data - eg. MODBUS find the data you want to send and receive from the Inverter. We will not write your programs for you. Unitronics Moderators here are Volunteers, Professionals who give their time to help others with their programming efforts. We can review your programs and guide you. DanT Quote Link to comment Share on other sites More sharing options...
PaulTailleur Posted April 11, 2019 Author Report Share Posted April 11, 2019 Hi Dan, I've already looked at the example and adapted the example to my case with a V700. I've downloaded them in the V700 but the motor don't run so i think it's the communication which have a problem ? Paul Quote Link to comment Share on other sites More sharing options...
DanT Posted April 11, 2019 Report Share Posted April 11, 2019 Hi; What are the communications parmeters used in the Inverter? If RS232 or 485 - Do you have the V100-17-RS4 or 4X Com Board installed, and Initialized in Visilogic ? Also in the Inverter( Inverter Manual) If Ethernet, do you have the IP Address Set up. Can you Ping the Inverter and the PLC from your computer? Is the Inverter using Modbus Protocol? Can you read any of the Modbus registers in the Inverter? Post your program and we can look at it. What version VisiLogic are you using? DanT Quote Link to comment Share on other sites More sharing options...
berkaykaya Posted April 12, 2019 Report Share Posted April 12, 2019 Hi Paul, First you must know Inverter Manual for Modbus Comminications Params. (Baud rate,data bits.. etc.) After you must make configurations with visilogic,you must set R.H.R for read freq,amper etc. You must set registers Inverter at your program. Quote Link to comment Share on other sites More sharing options...
