Kestralcontrols Posted May 21, 2019 Report Share Posted May 21, 2019 Hi all, I have a web trend (not live trend) which works for 4 minutes and 30 seconds. The data sampler stores 5 feed values every 30 seconds. The time axis on the trend is 10 minutes. The trend starts on LHS and continues the lines every 30 seconds, but once it reaches 4 minutes 30 seconds (the 10th sample) it stops. Is there a limit to the amount of data shown on a web trend. I know the data sample is working, because I can see historic trends. Sam Quote Link to comment Share on other sites More sharing options...
NoamM Posted May 22, 2019 Report Share Posted May 22, 2019 Hi Kestralcontrols, Quote Is there a limit to the amount of data shown on a web trend No, there is no such limitation. I suggest, Open a ticket at Unitronics "Help center" at https://support.unitronics.com/index.php the Support team will assist. Quote Link to comment Share on other sites More sharing options...
