MrMike Posted June 19, 2019 Report Share Posted June 19, 2019 How do I use variable Timer preset to enable user to set TD on HMI please help a newbie Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted June 19, 2019 MVP 2023 Report Share Posted June 19, 2019 Did you look at the Help file? The example is for an older PLC, but the basics are the same. When you place the Timer HMI element on the screen, link to the timer operand you want, check the Preset box, and the Keypad Entry box. Also, set up the Format and other niceties for your HMI element. That's all there is. 1 Link to comment Share on other sites More sharing options...
MrMike Posted June 20, 2019 Author Report Share Posted June 20, 2019 Yes problem solved, just needed a guideline such as yours. Thank you.... I'm having another Timer problem to program a coil that we be energized for a specific period of time but I will just start a topic for it. Thanks once again Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted June 20, 2019 MVP 2023 Report Share Posted June 20, 2019 2 minutes ago, MrMike said: I'm having another Timer problem to program a coil that we be energized for a specific period of time Use a TE Timer and activate it with a positive transition. 1 Link to comment Share on other sites More sharing options...
MrMike Posted June 20, 2019 Author Report Share Posted June 20, 2019 Thanks again you just saved me a lot of time... Link to comment Share on other sites More sharing options...
