Thomas Posted May 27, 2011 Report Share Posted May 27, 2011 Hello, Is there a way to respond to a button released? Thanks, Thomas Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted May 28, 2011 External Moderators Report Share Posted May 28, 2011 Hello, Is there a way to respond to a button released? Thanks, Thomas Hi thomas, Use a negative transition contact -INI- related to the button. I think the M91 has those, it s been a loooong time... TM Quote Link to comment Share on other sites More sharing options...
Emil Posted May 29, 2011 Report Share Posted May 29, 2011 Hi, Of course there is Negative transition contacts in Jazz and M91. Each button has Sistem Bit (SB) linked. To perfomr operation wne one release the button, as Tim stated, you need just to make condition -> Negative contact of related SB... If you want this to happen only on specific display, you can add to the condition compare SI2 to relevanr HMI. Quote Link to comment Share on other sites More sharing options...
