Milosh Posted December 23, 2019 Report Share Posted December 23, 2019 How to make communication between two Cinterion modems. On one side I have Jazz JZ20-T18 with Cinterion modem. Another side should be Scada with Cinterion modem. On PLC I make MODBUS slave communication, and direct connection between PLC and SCADA (RS232) works. I tried than to make connection between PLC-Scada via cinterions. 1. Initilaise PLC side modem and connect to Jazz. 2. Initilaise PCside modem and connect to scada. Communication not work. Does I need some steps to do? Which can be the problem? Maybe I should initialise PLCside modem and connect to scada? Quote Link to comment Share on other sites More sharing options...
Milosh Posted December 24, 2019 Author Report Share Posted December 24, 2019 Can I use MJ20-PRG with it's cable and modem plug MJ10-22-CS76? I tried simple SMS messaging, and always got SI180=3, Got unknown message... Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 24, 2019 Report Share Posted December 24, 2019 Yes, you can. But you have to use 6 wires cable. PRG module is isolated and required power supply. With MJ10-22-CS76 wires 1 and 6 supply power to PRG module. Quote Link to comment Share on other sites More sharing options...
Milosh Posted December 24, 2019 Author Report Share Posted December 24, 2019 OK, I use 6 wires cable MJ20-CB200, MJ20-PRG connector on PLC side, and MJ10-22-CS10 on modem side, but I always get SI180=3. I use Simple SMS example from U90 ladder set change PLC to Jazz JZ20-T18, and modify phone number in phone book. I tried with regular RS232 cable and PC I can send and receive message. I'm not sure why modem reply with Got unknown message... Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 24, 2019 Report Share Posted December 24, 2019 MJ10-22-CS10 is not for modem side, it is for PC side to supply power to PRG module. Use MJ10-22-CS76 for modem side. B.R. Quote Link to comment Share on other sites More sharing options...
Milosh Posted December 24, 2019 Author Report Share Posted December 24, 2019 1 hour ago, AlexUT said: MJ10-22-CS10 is not for modem side, it is for PC side to supply power to PRG module. Use MJ10-22-CS76 for modem side. B.R. Yes, you are right, my fault when writing post...The real situation is with MJ10-22-CS76. Sorry my fault. I use that cable but got message mentioned above. I'm not sure what is the problem. I Init modem from modem services. SIM card is valid and can send SMS. Quote Link to comment Share on other sites More sharing options...
Milosh Posted December 24, 2019 Author Report Share Posted December 24, 2019 Also I'm not sure, how Cinterion modem can supply power via 1 and 6 pins?! When you look on DB9 pinout for modem and pinout for PLC add-on port module PRG there are some differences. Also I look at the RS add-on module, also have differences with modem pinout. Maybe MJ10 connectors have some chip to do exchange or whatever??? My scenario is: MODEM & PLUG Cinterion BGS2T --- MJ10-22-CS76 CABLE MJ20-CB200 6 wires PLC & PLUG Jazz JZ20-T18 --- MJ20-PRG (add on module) Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 25, 2019 Report Share Posted December 25, 2019 Milosh, Visit https://unitronicsplc.com/support-technical-library/ Expand "Jazz & M91 Hardware" Expand "Jazz add-on modules and accessories" Scroll down and open JZ-PRG Specificationhttps://myzone-kza3sadj.netdna-ssl.com/wp-content/uploads/2016/06/MJ20-PRG_TECH-SPEC_10-09.pdf JZ-PRG Install Guidehttps://myzone-kza3sadj.netdna-ssl.com/wp-content/uploads/2016/06/JZ-PRG_INSTL-GUIDE_10-09.pdf Here you can find all details, include pinout. MJ10-22-CS76 internal wiring provide power to PRG module as well. *PRG module power consumption is low and used only to power RS232 communication. *When use CS10 adapter, you have to use RS232 port with full set of signals. Unitronics supply Prolific based USB-to-Serial converter supporting all signals. Other converters may have only RX, TX and Ground wires. And may not supply power to PRG module. B.R. 1 Quote Link to comment Share on other sites More sharing options...
