sunit Posted January 31, 2020 Report Share Posted January 31, 2020 I want to configure encoder interrupt function in US5-B5-TA30 and USC-B5-TA30 My application is as follows Fault tracking system. On encoder rotation I want to shift left a array of 1600 bits. After every 250 encoder pulses I will shift by 1 , can this be possible in the above two models Encoder resolution 250 ppr . on every 250 ppr the line displacement is 250mm. max speed of line will be 45m/min. after every 250 mm I want to shift 1 bit. Total length of line is 400 meters. Quote Link to comment Share on other sites More sharing options...
