mihai Posted June 29, 2011 Report Share Posted June 29, 2011 Hi everybody! Is there any possibility to connect a display, LCD screen or even a LED matrix, directly to a Vision V120 or higher PLC? I need to display two numbers on a screen, wich are calculated by the PLC. I need a large display, maybe 32 inches, that's why I can't use the integrated HMI. First option is to use a PC, connected to the PLC, but I want to know if it is possible without the use of a PC. Thank you! Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 29, 2011 MVP 2014 Report Share Posted June 29, 2011 You can purchase external displays with a serial interface. ASCII text is common, you may even be able to get Modbus. The link below is an example, these guys have a very high standard of product, with a price to match. You should be able to find similar products from other vendors if this one isn't in your price range. http://www.siebert-group.com/en/index.php 1 Quote Link to comment Share on other sites More sharing options...
mihai Posted June 30, 2011 Author Report Share Posted June 30, 2011 Thank you! Good solution! Quote Link to comment Share on other sites More sharing options...
