ETURSON Posted July 26, 2020 Report Share Posted July 26, 2020 Hi All, I was trying to connect Moxa ioLogik E1214 to Unistream USP-070-B10 over EtherNet IP. The Connection Status shows error code "0117", which explained as "Invalid Produced or Consumed Application Path". I created this node using "Add Node From EDS" file. I used the EDS file provided by the Manufacturer. I can see very short period of connection because the device name shows up correctly on the field, then disappears. Can anyone help me on this issue? Quote Link to comment Share on other sites More sharing options...
Pista Posted July 29, 2020 Report Share Posted July 29, 2020 Hi Eturson, I tried Type E1212 earlier and it worked properly. My PLC was USP-156-B10. Do you have it set up like this? TestMOXA.pdf Quote Link to comment Share on other sites More sharing options...
