nuno.penelas Posted August 11, 2020 Report Share Posted August 11, 2020 Hello, I am recently in the world of automation and today I came across these four errors that are described in the attached image. Can someone help me. Thank you very much in advance. Best regards, Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 11, 2020 MVP 2023 Report Share Posted August 11, 2020 This simply means that you are having some intermittent issues with communicating with the PLC. Is this UniLogic or VisiLogic? How are you connected to the PLC exactly? Link to comment Share on other sites More sharing options...
nuno.penelas Posted August 11, 2020 Author Report Share Posted August 11, 2020 It is Visilogic and I am connecting via internet (TCP/IP) Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 11, 2020 MVP 2023 Report Share Posted August 11, 2020 Moved to the correct forum. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 11, 2020 MVP 2023 Report Share Posted August 11, 2020 39 minutes ago, nuno.penelas said: It is Visilogic and I am connecting via internet (TCP/IP) It's just telling you that some packets were dropped and it had to retransmit. If the process finished then all is well. If it aborted, you need to improve your connection. Link to comment Share on other sites More sharing options...
nuno.penelas Posted August 12, 2020 Author Report Share Posted August 12, 2020 Thank you very much for the help Link to comment Share on other sites More sharing options...
