Mark_B Posted August 20, 2020 Report Share Posted August 20, 2020 Hello I've recently entered the industry and I am having issues with the ASCII string element. I have an ASCII String keypad that on a button press, writes its current text to a table, then reads its text from another row on the table. From my testing, the MIs containing the text are changing values as they should, but the HMI element is not updating. I have attached the current variables assigned to the element. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted August 20, 2020 MVP 2014 Report Share Posted August 20, 2020 Hi Mark, Welcome 🙂 Try pulsing SB31 after updating the vector of MIs. Make sure it's a one-shot pulse, not a direct condition. Simon 1 Quote Link to comment Share on other sites More sharing options...
Mark_B Posted August 20, 2020 Author Report Share Posted August 20, 2020 That seems to have worked. Thanks a ton. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted September 2, 2020 MVP 2014 Report Share Posted September 2, 2020 👍 Quote Link to comment Share on other sites More sharing options...
