DannyC Posted July 15, 2011 Report Share Posted July 15, 2011 Hi, We have a M91-2-T1 that we haven't used for a while, and have just got it out again recently. I am trying to communicate with the PLC via RS232, but cannot communicate with the PLC. I am using: USB to serial cable (Prolific, driver version 3.3.10.140), connected to; DB9-RJ11 cable which we made according to the pin assignments in the U90 software manual (we also have another one with the RxD/TxD reversed because we thought we had the two around the wrong way) I also tried using an older computer which has a RS232 port, and no luck there either, so that ruled out the problem of the USB to serial cable. I have checked the COM port and settings (reset everything back to default), and they all seem fine. Is there a way I can test if the connections are correct by say, use HyperTerminal to send commands to the PLC, or is there any way I can find out what the problem might be? Many thanks, Danny Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 13, 2011 Report Share Posted December 13, 2011 Hi Danny, I am sorry for missing your request for help. Was the problem solved or you need further help? * PLC can not answer to any HyperTerminal input as by default it use VisiLogic communication protocol. ** To check cable or adapter, you need to shortcut pins 2 and 3 at 9 pin RS-232 connector. Entering any symbols from HyperTerminal will echo back. Quote Link to comment Share on other sites More sharing options...
