Tim Pritchard Posted November 18, 2020 Report Share Posted November 18, 2020 Hey Guys, The Title really says it all.. But is there a tag limit either by STRUCT or Element for the Unistreams OPC UA Server? If there is a limit, is it based on the hardware? Cheers Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 18, 2020 Report Share Posted November 18, 2020 Can you explain problem, or it is common question? 1. What you did. 2. What's going wrong. B.R. Quote Link to comment Share on other sites More sharing options...
Tim Pritchard Posted November 18, 2020 Author Report Share Posted November 18, 2020 I had a project on a US5/7-B5-R38 that I used the OPC UA server for communications. I noticed that when i got over 900 or so tags it showed an error. Unfortunately I don't have the unit to replicate the issue now. Using a USP-070-B10, I loaded the software and didn't find the same issue. Hence the question about if linked to hardware? cheers Quote Link to comment Share on other sites More sharing options...
