TheDave2 Posted July 27, 2011 Report Share Posted July 27, 2011 "One or more of the selected elements cannot be resized / aligned / rotated" ARRRRRRRRRRGGGGGGGGGG !!!!!!!!!!!!!!! Please Please Please, don't try to protect me from doing what you all think are silly things. They aren't. It appears that when trying to Make Equal Spaces (Vertical) , the existing objects are also checked against themselves. I have roughly drawn 9 horz. lines in a vertical layout and want to make them equal spaced. No can use the tool. Also, when the equal space tool can be use, it will also move the bottom object. It looks like the code for this is determining the spacing as an integer when it should be using floating point and not just applying the spacing to only the middle (not end) objects but also the end one. Link to comment Share on other sites More sharing options...
