hamfam Posted March 5, 2021 Report Share Posted March 5, 2021 Help me guys please I have two control loops PID P1 and P2 P1 is working fine and it has logic to store 0 to "control value" without compiler faults P2 is working fine but it wont allow store 0 to "control value" , system responds compiler "tag is read only" Now i am thinking that P2 is wrong so i create a P3 and its the same P2 but it wont allow store 0 to "control value" , system responds compiler "tag is read only" when i duplicate P1 to P11 , the P11 acts the same as P1 and it compiles ok and store 0 to "control value" without compiler faults Now i am sure the logic should not allow me to store 0 to "control value" and the compiler is right but why does it work fine on P1 but it wont work on P2 Link to comment Share on other sites More sharing options...
Rivka Posted March 9, 2021 Report Share Posted March 9, 2021 Hello @hamfam, The member "control value" is actually supposed to be read-only. When reopenning your project, and compiling with "Rebuil All", does the assignment still pass compilation? Did you create P1 and P2 at about the same time? I guess any "PID config" struct that you create from now and then gives a compilation error on such an assignment, right? I suggest you to send your project to R&D (through support), it looks that the P1 tag is somehow corrupted. (you don't really have to, if you wish, you can just create a P3 variable, use the find & replace feature to replace all P1 occurrences with P3, delete P1, then rename P3 to P1) Hope that helped you Best regards, Rivka Link to comment Share on other sites More sharing options...
