screw maker Posted August 1, 2011 Report Share Posted August 1, 2011 at samples in help menu one can get version by /00 command using hyper trminal. Can you tell me by what coommand I can reset Jazz through hyper terminal Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 2, 2011 Report Share Posted August 2, 2011 Hi, The command to reset should be /00CCE2B Make sure at the end of the string to send <CR> Quote Link to comment Share on other sites More sharing options...
