Cosine Posted April 14, 2021 Report Share Posted April 14, 2021 Good Day Everyone, I'm having a problem installing UniLogic Ver. 1.31. I got pass the UniLogic setup and the Welcome Dialog but after the InstallShield Wizard the attached picture will pop-up and will terminate the setup. I need to update my currently installed UniLogic Ver. 1.26 in order to try the sample project for UniCloud since it's asking to open a newer version to open it. I've already uninstalled the UniLogic in Control Panel and follow some instructions that I saw on how to fix this problem except for the MsiZap.exe part since I can't find a way to download it. Can someone help me on this one? Thanks! Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 14, 2021 Report Share Posted April 14, 2021 Follow next article: https://support.unitronics.com/index.php?/selfhelp/view-article/how-to-fix-catastrophic-failure-when-install-uninstall-visilogic Delete directory named {83C5EAE0-FB24-4ACD-848A-9286B0DC30C1} Then repeat installation. Quote Link to comment Share on other sites More sharing options...
stembera Posted September 7, 2021 Report Share Posted September 7, 2021 Alex, your advice was intended for case of corrupted VisiLogic installation. Author had a problem with UniLogic installation. (I have the same problem today so I am curious if it was solved before). Quote Link to comment Share on other sites More sharing options...
Cosine Posted September 8, 2021 Author Report Share Posted September 8, 2021 Hi Stembera, I solved it using the instruction of Saragani in this post: Quote Link to comment Share on other sites More sharing options...
