Michael McCormick Posted August 3, 2011 Report Share Posted August 3, 2011 Hi. We've been using M90 with GSM modems for SMS for some time now. However, we've been havin a lot of problems with the latest enforma modems. They don;t seem to want to work! An example is one that was installed to replace an old sony GM29. The original modem was working fine, sending SMS. The new one works with the same code, but only sends SMS for one day before needing to be power off and back on again. Has anybody had any issues with the M90 / M91 and GSM modems? Does anybody have any additions to the initialisation strings that could help? Thanks, Michael Link to comment Share on other sites More sharing options...
AlexUT Posted December 13, 2011 Report Share Posted December 13, 2011 Hi Michael, I am sorry for missing your request for help. Was the problem solved or you need further help? Link to comment Share on other sites More sharing options...
DavidThornton Posted February 8, 2016 Report Share Posted February 8, 2016 Hi, Is there a resolution known for this? This was a while ago now, but I am having the same issue with an ETM9400-1 modem. Is it PLC or Modem issue? Link to comment Share on other sites More sharing options...
AlexUT Posted February 8, 2016 Report Share Posted February 8, 2016 Hi DavidThornton, It seems that Michael found and fixed problem. Modem you mentioned - ETM9400-1 - is not in supported modems list. So there is no warranty that it will work with GPRS. It may work, or may not work in SMS mode, when selected "Other..." type of modem. Enfora is supported for years, and in most of cases have no problems. Problems will arise, when cellular signal level is not good. *For Enfora modem minimum CSQ level is 11. For areas with a big signal fluctuation it is recommended to check, if antenna is not covered by trees, etc. If signal is low as result of weather condition - you have to check signal quality each 5-10 min., and make COM INIT until CSQ will show good signal. As well, antenna re-positioning, or use antenna with highest gain, may solve problem, or extend hours with a good cellular signal level. B.R. Link to comment Share on other sites More sharing options...
DavidThornton Posted February 10, 2016 Report Share Posted February 10, 2016 Thanks for the reply Alex. This modem is supplied here in Australia by the Unitronics dealer, it is working fine. I just have the same problem as stated by the OP, of it only working for a short period of time (1-2 days) before needing to be reset. I was hoping for a fix to that particular issue, not sure if its the modem or PLC. My biggest problem is fault finding, as I can't look at code and use modem at the same time on an M90. Link to comment Share on other sites More sharing options...
DavidThornton Posted February 11, 2016 Report Share Posted February 11, 2016 I have made a 5 min timer so after timeout, if SB182 is also true, it sets SB180 until SB181 becomes true. This assumes SB182 will become true when my SMS failure issue occurs. Is SB182 only valid straight after an initialization attempt, or will it still work at any time after initialization? Link to comment Share on other sites More sharing options...
