A.a.p Posted June 18, 2021 Report Share Posted June 18, 2021 Hi, i am using jz20-t40. And my client want to be able to set min. and max. values for analog inputs (water probe). (4-20mA) I don't really know hot to make it. When he pulls the water probe out of water he sets it as 0 (%) and puts it back into water to the point of which he will set it to be 100 (%). Any help is very appriciated, Thanks in advance. Quote Link to comment Share on other sites More sharing options...
DanT Posted June 18, 2021 Report Share Posted June 18, 2021 Hi In U90 Ladder program, Look under Help - Examples - Flow Totalizing..- Tank Level Single Pump Example. This will answer your questions. DanT Quote Link to comment Share on other sites More sharing options...
