Jpalas Posted July 12, 2021 Report Share Posted July 12, 2021 New on this forum so, Hi there So I’ve been trying to complete a program to a Schneider PLC in Ladder but having some doubts. I’m trying to add a timer, this needs to add a block of time every time a contact is cloded (coin validator). Tried so use a counter and a pulse timer, but doens’t add time to it. Could someone give me any idea? Using a Schneider Modicom M221 24 I/O and Ecostruture Machine Expert Basic Thank you so much Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 12, 2021 Report Share Posted July 12, 2021 Jpalas, This forum is for Unitronics PLCs. If you are working with Schneider PLC only - we cannot help. If you should interface from Schneider PLC to Unitronics PLC, then better explain what you should do on Unitronics PLC and what communication protocol you use to communicate between Schneider PLC and Unitronics PLC, and what Unitronics PLC model supposed to use. B.R. Quote Link to comment Share on other sites More sharing options...
