erwinnd Posted January 6 Report Share Posted January 6 Hello everyone, I'm currently communicating with a device using RS232. I'm using the build message function to convert a message from message composer to a buffer. Then I transmit the message using the COM Tx function. I then receive a certain amount data packets and use the COM Rx to convert these into a buffer. I programmed my own function to convert the values of this Rx buffer into a proper response but it is very inefficient because I manually check each index of the buffer for its value and convert it to the corresponding numeric value. I think the Parse Message function is build to do this job for you, however, I can't seem to figure out how to use it to convert a buffer into a message. Can anyone explain the usage of the Parse Message function? Thanks in regards! Quote Link to comment Share on other sites More sharing options...
AlexUT Posted January 6 Report Share Posted January 6 1. You have to pass to Parce function full message. In case you youse RS232 ot low speed, PLC will read fragments of full message at each scan. To read a full message, you have to check "Last Bytes waiting in Buffer" for your RS232 to be a string termination character, And only then read buffer. After this you can parce buffer content. Quote Link to comment Share on other sites More sharing options...
