chris1 Posted August 28, 2011 Report Share Posted August 28, 2011 Hello to everyone, just a simple question: Can I have a V350 running as a web server and exchange data with a V130 over ethernet at the same time? My Setup: V350 with rs232 on COM1 used for other communications and ethernet V130 with ethernet only Do I need special configurations to make it work (e.g. port numbers). Thanks a lot Chris 1 Quote Link to comment Share on other sites More sharing options...
Emil Posted August 28, 2011 Report Share Posted August 28, 2011 Hi Chris 1, Of course YES. You can open 4 ports at a time and communicate simultaneously with 4 devices in the network. Let's say in your case one port will be busy with WEB server. You still have 3 additional free! Quote Link to comment Share on other sites More sharing options...
