System Error struct is not being used. Consider using it to get error indications
Mark Vonckx
Thank you for the reply.
I always get the message of the struct not being used, after compiling.
this leaves me two options:
Implement this in the program. However, it is not clear how this should be done.
or find a way to avoid having the message as it is enoying.
If you can send me a guide how to implement the struct this would be very helpfull.
