carver Posted September 10, 2011 Report Share Posted September 10, 2011 I'm using a V350-35-TA24 with 2 serial ports (RS232) which are connected to exernal devices. To simplify programming and debugging I would like to have a third serial port RS232. Does the EX-RC1 provides this? Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted September 13, 2011 MVP 2014 Report Share Posted September 13, 2011 You should be able to do that via the EX-RC1, or any other Unitronics PLC with CAN bus. Quote Link to comment Share on other sites More sharing options...
