Playing audio file via Web Server
richlinares
Hello,
Is it possible to play an audio file via the webserver?  i have a program in which i have created a webpage that is being displayed on a tv monitor.  i have a bit setup to turn on once a limit has been exceeded and wanted to see if i could use to trigger the audio possibly via the use of a hyperlink but cant find any examples.  Hoping someone can help me out.
Thank You,
RL
  • NoamM changed the title to Playing audio file via Web Server
