Swervomotor Posted January 27 Report Share Posted January 27 Hi, Im using Function Block "MC Apply Torque" with the Unitronics Ethercat servo drive. The help file defines the torque ramp (parameter E) "Units defined in Axis Configuration, torque per sec." Does anyone know the normal "scale" of this number and what a higher number vs a lower number here means in practice? I have submitted a help ticket to support but was hoping someone knew here. Thank you. -Swervo Quote Link to comment Share on other sites More sharing options...
Ivgeny Posted February 5 Report Share Posted February 5 Hi Swerko, The ramp is the raising portion of torque / sec. If you willing to apply 5Nm and get it in 5 second, the ramp is 1Nm/sec. Quote Link to comment Share on other sites More sharing options...
