RickL Posted February 26 Report Share Posted February 26 I have several MB types that I need to convert to MI types before I can use them in a logic "OR" function. An example of one: I need to convert my MB111 (set =1 / reset =0 type) this is my MB " A" input into the "AND" function block Looks like the converted MB111 will reside at my newly assigned, lets say MI222 location - "B" input of the "AND" function block I dont understand the "C" input assignment and how to set it. My span of numbers are 0 to 1 only. BIT->NUM: B (Destination) < what should this look like? do I erase (Destination) ? BIT->NUM: C (Length) < what should this look like? do I erase (Length) ? Thanks! Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 26 Report Share Posted February 26 Is it an explanation in Help: Of course, Output result is changed in accordance to operation and inputs conditions. Do it in Ladder to see how it works. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted March 1 Report Share Posted March 1 On 2/26/2023 at 5:30 AM, RickL said: I have several MB types that I need to convert to MI types before I can use them in a logic "OR" function. An example of one: I need to convert my MB111 (set =1 / reset =0 type) this is my MB " A" input into the "AND" function block Looks like the converted MB111 will reside at my newly assigned, lets say MI222 location - "B" input of the "AND" function block I dont understand the "C" input assignment and how to set it. My span of numbers are 0 to 1 only. BIT->NUM: B (Destination) < what should this look like? do I erase (Destination) ? BIT->NUM: C (Length) < what should this look like? do I erase (Length) ? Thanks! You don't need to do conversions; logic functions are not intended to be used on BOOLEAN values those functions are for INTEGER values. in the ladder logic you already are working with logic functions already. AND: -----| |---| | ------( ) OR: ---| |----.----------( ) ---| |----' Quote Link to comment Share on other sites More sharing options...
