ORSO2001 Posted September 27 Report Share Posted September 27 hi All, I need a software button to be pressable only by the user connected in VNC and not by touching the real touch panel...i did it checking the VNC connection bit and the VNC touch bit and obviously a specific bit for the button command...I was connected at the same time by VNC and by the "online" mode of the Unilogic. the VNC bit connection arise almost immediatelly after that the VNC connection is establish...so ok the command bit of the button immediately update its status...so ok the touch bit of the VNC need untill 1/1.2 seconds (sometimes few cents) to be enabled...I put a timer to measure this. is this latency "normal" or not?...if not what could be the causes? thanks Quote Link to comment Share on other sites More sharing options...
