David1986 Posted September 30, 2011 Report Share Posted September 30, 2011 Hi, I would like to configure a Vision 350 as slave in a profibus network. I have downloaded the latest version of Visiologic and I have found in the help some information of how to configure it but in the software I can't fin the profibus configuration block which is shown in the help. Perhaps someone could help me about that and tell me where can I find this configuration block. Also, I need to explain to a costumer how configure the J1939 protocol...I have found information but I can't check it correctly. Could someone send me any example of how to configure it? Thank you so much for your help and best regards. Quote Link to comment Share on other sites More sharing options...
Ofir Posted October 17, 2011 Report Share Posted October 17, 2011 Hi David, First make sure you are using the latest Visilogic version 9.3.1 You can find the Profibus Configuration block under COM menu. (Make sure the hardware is configured to V130 or V350). Attached is a very basic example which sends 1 PGN and receives 2 PGNs. J1939.vlp Quote Link to comment Share on other sites More sharing options...
